Fixing oil in spark plug and other engine oil leaks on the 3.2
#131
Here are both valve covers clean and almost ready.
#132
Here are the valve covers with new gaskets installed.
#133
I used alcohol to remove oil residues from the cylinder head sealing surfaces.
#134
I installed the valve cover on the driver's side and torqued the bolts to 9 Nm following the sequence as shown here: youtube.com/watch?v=94-kTXahcxs&t=23m06s
Then I gently connected the breather hose.
#135
Before installing the valve cover on the passenger's side, I installed the fuel sensor holder screw I removed earlier to be able to pull out the cam girdle. The magnetic pen head was useful here too.
I torqued it to 10 Nm.
#136
I cleaned the cylinder head sealing surfaces with alcohol.
#137
I installed the valve cover on the passenger's side and torqued its bolts to 9 Nm following the sequence as shown here: youtube.com/watch?v=vVM1uzd1k44&t=46m10s
Caution! Caution! The vacuum hose that comes from the back of the engine and connects to the vacuum pump up front normally passes under the breather hose. I did not realize this until later when I was connecting the vacuum hoses and noticed something wasn't right. I then had to remove the valve cover again to be able to pass the vacuum hose under the breather hose. So make sure you pass the vacuum hose under the breather hose at this point.
#138
Replacing spark plugs and installing ignition coils
I first removed all spark plugs.
#139
Then I cleaned oil from the holes
#140
Here are old vs new spark plugs.
