A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
gas gauge woes
Old 09-01-2006, 06:45 PM
Audiworld Senior Member
jefman's Avatar
Default gas gauge woes
Woke up fell out of bed, filled the car in seconds flat. (Yes, you may sing along)
On the way, I noticed the gauge read flat out empty and the dashboard displayed the gas icon. After 10 minutes, the icon disappeared and the needle zipped up to the full position. Very strange. I know for sure the gas cap was turned past the clickety-click point. Has this happened to anyone else? Also, my trunk lock sometimes catches and sometimes does not.
Old 09-01-2006, 07:04 PM
New Member
iove's Avatar
Default There's a brand new bulletin on this...
they will need to reprogram your instrument cluster to the latest software..90-05-03.
Old 09-01-2006, 07:18 PM
jefman's Avatar
Default I just went to the dealer for my 25k oil change
and they updated the passenger airbag software.
Thanks for the info.
Old 09-03-2006, 03:58 PM
safelder's Avatar
Default Me too...
They say I need a new fuel sender, and they don't have any. Part is on national backorder.
Old 09-03-2006, 06:02 PM
TulsaTime's Avatar
Default If your keyfob is in a pantspocket and you lean close to the car, sometimes the lock will reopen...
Of course, this is if you have advanced key. If not, you might check the in-trunk panic lever adjustment.
Old 09-03-2006, 06:22 PM
New Member
ciberg's Avatar
Default I had the same fuel gauge problem, i filled with Premium Diesel and it dissapeared...
... now i fill with normal Diesel, but when i fill with a cheaper diesel the problem returns.
Maybe the same with Gasoline.
Old 09-05-2006, 04:04 PM
jefman's Avatar
Default Re: Me too...
sounds like the same problem Audi had in '99. Before they announced the recall, I thought my garage attendants were stealing gas from me
Old 09-05-2006, 04:13 PM
jefman's Avatar
Default Re: If your keyfob is in a pantspocket and you lean close to the car, sometimes the lock will reopen
no advanced key, trunk lock has gremlins. I'll check the inside emergency release. I didn't think of that, never been locked inside the trunk before Thanks anyway.
Old 09-05-2006, 05:54 PM
New Member
ciberg's Avatar
Where is the in-trunk panic lever? does the European A6 has one, or it's a USA thing??
Old 09-05-2006, 06:12 PM
Life Rules's Avatar
Default I believe there's a TSB on the trunk latch...
I had to have mine replaced. It started out just not catching sometimes, then got to where it would hardly ever catch, and if it did, I wouldn't want to use the trunk again for a while...
They replaced the latch and all is well!
Quick Reply: gas gauge woes
