Has any one else have bent valve on their C6 3.2?
So i had the rear timing covers sealed when i found out that my passenger flex pipe cracked.
i thought i was done with the engine leaking but turns out despite changing the valve cover gaskets the problem persisted. After further examination it was determined that the vacuum pump was leaking along with the O rings and the valves were bent causing oil to leak into the spark plugs chamber. Surprisingly it didn't throw any faults. The car has 124500K Miles its a 2007 C6 with a 3.2 L engine.
Part number for passenger side
Bent Engine Valve Covers
Gasket for vacuum pump
To fix the issue i had to buy two new valve covers for the engine part numbers
06E103472L passenger
06E103471G driver
get the o rings gasket
2 gaskets for your vacuum pump.
And a set of new engine valve covers. ECS has them for $203 a piece.
06E103471G driver
"the valves were bent causing oil to leak into the spark plugs chamber."
This is complete nonsense. Sounds to me like your valves are fine.
But to answer the question, I've replaced bent valves on the 3.2, but only after some sort of chain guide failure. It's actually easier to get the valves out than on the 30v engines.
06E103471G driver
06E103471G driver
Not sure if I follow the post. I had the flex exaust coupling cracked. It caused the car to make quite louder noise when the engine was under load. There was no error codes.
acarney
44
11-18-2015 10:30 AM
hermosa_a6
10-12-2010 03:51 PM
SteveK-OO (MN)
07-01-2008 09:06 AM
