Help with A6 2006, runs very poor when cold, but fine when warm
Barely runs when cold (any outside temperature). After it runs about several minutes, if you could keep it running, it then runs fine and takes gas well.
Don't have VAG codes, only OBDII ones:
P0171, too lean bank one,
P0174, too lean bank two.
Changed coolant temp sensor, no difference. Fuel running pressure about 60 psi. Sorry my software won't allow me to get VAG codes. Any ideas?
Thanks!
Jim
Thanks!
Jim
16555/P0171/000369 - Fuel Trim; Bank 1: System Too Lean
Possible Causes
Mass Air Flow Sensor (G70) defective
Possible Solutions
Check Mass Air Flow Sensor (G70)
Check Fuel Pressure Regulation
Check Fuel Pump
Check Injectors
Check Intake System for Leaks
Check Exhaust System for Leaks
Check Secondary Air System for Leaks
Check Vacuum Pipes for Leaks
Retrieved from "http://wiki.ross-tech.com/index.php/16555/P0171/000369"
Possible Causes
Possible Solutions
Check Fuel Pump
Check Injectors
16556/P0172 - System Too Rich, Bank 1
Possible Symptoms
Irregular behaviour
Possible Causes
Fuel system
Excessive fuel pressure
Leaking or contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Air leaks after the MAF
Vacuum leaks
Improper seated engine oil dipstick
Stuck EGR valve
Oil overfill
Cam timing
Cylinder compression
Exhaust leaks before or near HO2Ss.
Retrieved from "http://wiki.ross-tech.com/index.php/16556/P0172"
Possible Symptoms
Irregular behaviour
Possible Causes
Fuel system
Vacuum leaks
Stuck EGR valve
Oil overfill
Cam timing
Biggeek
02-11-2007 08:35 PM
Redaudifor
01-24-2006 07:26 AM
