Help! Car won't go into gear
First, thanks for the good advices, I have finally got the car to start after a serious water damage. However, I still cannot get the gears to engage.
Here is what I have replaced so far:
1. TCU (the original was completed rusted)
2. Brake light switch
3. Shifter-lock solenoid
4. Replaced the Shifter Selector Circuit-board
I have several abnormalities:
1. The parking light on the shifter lights up only when the gear-lever is on neutral, never on “Park” position.
2. The tranny does not in engage when in drive “D”, nor does it engage in any other position for that matter.
3. I can only start it when in neutral position.
Here is the VAG output:
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
Mileage: 230240km/143064miles
Address 01: Engine Labels: 078-907-551-AHA.lbl
Part No: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR AT D01
Coding: 06252
Shop #: WSC 02324
VCID: 6CC914DF36F9
7 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16689 - Cylinder 5: Misfire Detected
P0305 - 35-10 - - - Intermittent
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-10 - - - Intermittent
18008 - Power Supply Terminal 15: Voltage too Low
P1600 - 35-10 - - - Intermittent
Readiness: 0010 1101
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4B0 927 156 G
Component: AG5 01V 2.8l5V USA 8509
Coding: 00000
Shop #: WSC 00000
VCID: 2B4BD7C3F377
2 Faults Found:
01236 - Shift Selector Locking Solenoid (N110)
31-10 - Open or Short to Ground - Intermittent
00668 - Supply Voltage Terminal 30
31-00 - Open or Short to Ground
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 G
Component: A6-Klimavollautomat D55
Coding: 00160
Shop #: WSC 02324
VCID: 1E2D0E17B0C5
2 Faults Found:
00792 - A/C Pressure Switch (F129)
01273 - Fresh Air Blower (V2)
17-10 - Control Difference - Intermittent
Address 17: Instruments Labels: 4B0-919-xxx-17.lbl
Part No: 4B0 919 930 B
Component: C5-KOMBIINSTR. VDO D11
Coding: 07262
Shop #: WSC 00000
VCID: 27432BF3EF9F
1 Fault Found:
00771 - Fuel Level Sensor (G)
30-00 - Open or Short to Plus
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
Shop #: WSC 00000
VCID: 2C49D4DFF679
2 Faults Found:
07-10 - Signal too Low - Intermittent
06-10 - Signal too High - Intermittent
Any additional pointers/advices will be highly appreciated.
76 77
Coding: 06252
Shop #: WSC 02324
VCID: 6CC914DF36F9
7 Faults Found:
Coding: 00000
Shop #: WSC 00000
VCID: 2B4BD7C3F377
2 Faults Found:
Coding: 00160
Shop #: WSC 02324
VCID: 1E2D0E17B0C5
2 Faults Found:
Coding: 07262
Shop #: WSC 00000
VCID: 27432BF3EF9F
1 Fault Found:
Coding: 00001
Shop #: WSC 00000
VCID: 2C49D4DFF679
2 Faults Found:
DoubleB
VAG-COM Discussion
03-10-2009 04:48 AM
