A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
MMI 2G update
Old 05-20-2018, 12:39 PM
Amir Denis's Avatar
Default MMI 2G update
Hello guys i have a MMI 2G on Audi A6 09.2004 and i cant find an update for the MMI i tried to insert audi 5570 version that i did update on A8 D3 but not working on the A6 2004 what should i do ?
Thanks
Old 05-21-2018, 12:01 PM
raj99's Avatar
Thanks
Where in the world are you located? The C6 in the US needs the 4610 update as the latest. Did you read the "sticky" thread a the top of the forum? https://www.audiworld.com/forums/a6-...steps-2607361/
FWIW, your S/W ver is: 5.0.0, which means it's NEVER been updated since it left the factory.
Old 05-21-2018, 01:24 PM
Amir Denis's Avatar
ok i understand i live in europ is there any chance to update it ?
Old 05-22-2018, 03:23 AM
hrc4u's Avatar
I've updated mine without issues to 5570..
What error do you get when trying to update?
Are you using original update cd's or downloaded?
/H
Old 05-22-2018, 03:25 AM
Amir Denis's Avatar
/H
i took a downloaded one i updated with it on A8 easy but on the A6 i get error wrote in german
Old 05-22-2018, 08:31 AM
raj99's Avatar
Perhaps it's the dnld ver or your CD is mehh or you didn't do the update correctly. Start with a legit source (i.e. Audi direct) and try that.
Old 05-22-2018, 01:34 PM
hrc4u's Avatar
you need the whole 3cd set...or you maybe know that already?
cheers/H
Old 02-10-2020, 10:00 AM
binhbees's Avatar
I purchase the 3 cd set update Genuine from amazon, for audi A6 C6 mmi update will this work just by loading onto cd player in car? as i am confused by some post on youtube about dissconnecting the optical amp cable..?
hrc4u (02-11-2020)
Old 02-11-2020, 09:57 AM
hrc4u's Avatar
See here for instance :
MMI 2G software update to version 5570 - mr-fix.info
Old 03-03-2020, 01:08 PM
cal3thousand's Avatar
Originally Posted by alexbnz
please tell from what version did you update fine from 5 or 6 ? thanks
I just updated My A8 last night to 5570 and previously did my A6s with the same CD set. 3 discs.
if you have 4610, then you just need the last disc.
Quick Reply: MMI 2G update
