MMI Shutdown
MMI Shutdown
Hello,
I'm the second owner of a 2005 A6 3.2. It's a great and expensive car to own! It's got the MMI high. I'm located in the US..
So I've got an issue happening right now -and yes I've searched - The MMI keeps crashing. This just started happening this weekend. Others have reported similar issues but what mine is doing seems stranger than average. I'all give a brief chronological account.
this last winter when it was really cold there were a couple times when I started the car I got a piercing screech that came over the speakers and wouldn't stop. Each time I unplugged the connection to the bose amp in the truck. It seemed to fix the issue.
no issues through the spring.
Saturday night the MMI crashed on the interstate. Pulled of and did a reboot on it. Didn't work. Coincidently at the same time the rpm and speedometer lights stopped working while the light switch was in the "auto" position.
Sunday the MMI worked for a little bit then crashed again. This time I unplugged the Bose amp again let it sit and it worked great. Later it crashed again and came back up trying to pull info on radio stations and the photo kept happening.
so is this a software, MMI or Bose amp issue? Probably all three. It's going into my local independent Audi shop tomorrow.
Clarification: The rpm/speedo lights work when the light switch is on. Just not in the auto position.
there is no moisture or water damage I can find in the truck where the nav, tuner, satellite, and amp are.
How old is the battery in the car? The car started acting weird when the battery seemed to be fine. The dealer did a battery test and told me it failed load test. BT started not pairing; but the car could start every single time.
the battery is 3 years old. It shows 100% when I run the test on the dash, but I have zero idea if that's correct or how accurate it is. I've got zero issues with it starting
Well, I pulled the fuses and did the hard boot. It's worked all day. I will still take it in and have it looked at. Will the hard boot reset any codes that were thrown ?
Well it crashed again.. The shop wasn't able to hook up at all. Didn't have time to leave it. Pulled the fuse again and it works. It really seems like it could be a software issue. The MMI is running 1070, so I can jump directly to the 4610.. Anyway I ordered an OEM set of discs and I'm going to attempt the update this weekend.
Well, my local Indy guy can't figure it out. So now it's going to be going to component component, starting with the blue tooth under the passenger seat.
Took it 6 hours round trip this weekend and it worked 3/4 of the time, however it was really strange it would show the Sirius presets but it would play Sirius radio. CD player kept skipping.
tried updating software again. It crashed, so who knows if the MMI is fried.
any ideas guys? I guess at this point I might be looking at a new MMI? Tons of conflicting info out there. At I looking at a 2k bill?
any help would be appreciated, very appreciated
OOOOya
49
05-23-2007 09:13 PM
RS6er
Audi 100 / A6 (C4 Platform)
03-26-2007 05:37 PM
still a stoner
9
07-26-2005 01:49 PM
SparTTan
9
11-12-2002 10:00 AM
