Navigation Pre-Wiring -- Question Though
So I have these connectors and fiber optic loop in my truck under the Satellite Radio module:
Obviously, I Need the 4E0 919 887 (x) dvd unit for the NAV. The 3 wire connector is obvious. The removal of the fiber optic loop and plugging in of it to the nav is obvious. But........There are the green and brown antenna connectors. Which gets used? Every single dvd unit I've found shows a single connector on the back. Any ideas what the other connector is for, and which color gets used for the nav?
You already have Satellite radio?
The brown one, I believe, is supposed to be Satellite radio.
The green one not so sure.
I believe the antenna connections are all fundamentally the same, so you could try hooking up the GPS to the green and start off.
Hmm......I think I mistook an MMI module for the Sat module. Apparently I do NOT have the Sat installed. Does have the shark fin antenna though. Hmmm.......May not be as plug and play as I was hoping to find. Oh well, gotta get the parts first.
That would be killer if it was. If not, I can always use one of those hideaway ones based off the research I've seen. Or I'll just wire it in. It's not rocket science.
You might not need to remove the shark fin to do that , there is already a connector installed you just need an extension. Read last post: Navigation is not active.
