A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Need help ASAP !!! 2007 A6 Quattro headlight switch removal?
Old 10-19-2018, 05:58 AM
Vigilante49's Avatar
Default Need help ASAP !!! 2007 A6 Quattro headlight switch removal?
I’ve gone through most of the threads on here but can’t seem to find one that’s similar to my car, the push and pull doesn’t work, taking off the side trim doesn’t work because ac/heat vent is on the way of my hand and the switch and a screw driver won’t push it out, p.s my light switch is in the same panel as the dash instrument cluster, will attach photos soon, explanation with photos or diagrams would be highly appreciated
Old 10-19-2018, 08:27 AM
gsjohal's Avatar
Hi.
You need to take out the plastic pin holding the air duct in place, remove the duct then reach in and push out the switch from behind.
Old 10-19-2018, 09:50 AM
Originally Posted by gsjohal
Hi.
ok I’ll try that and see how it works am working till midnight tonight but I’ll send a picture and you can direct me from there
Old 10-20-2018, 04:44 AM
Hi.
Please point it out to me
Old 10-20-2018, 05:32 AM
georgeb944's Avatar
This should help.
File Type: pdf
Old 10-20-2018, 05:39 AM
Thank you you’re a live saver just pulled the damn thing and it came off thanks again
mcable
10-16-2011 11:49 AM
eurovan5150
11-02-2008 02:38 PM
audikillsbmw
28
09-22-2007 04:43 AM
Quick Reply: Need help ASAP !!! 2007 A6 Quattro headlight switch removal?
