A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
No audio output when it is cold
Old 02-21-2018, 02:26 AM
Jorgos's Avatar
Default No audio output when it is cold
Hi,
I have Audi A6 C6 from 2010 with MMI 3G (Hdd, joystick in ****). I have following issue: There is no sound when i come to my car when there is cold outside (less than +5deg C). Sound does not work for around 5-10minutes then it works properly. There is no errors in VCDS (there used to be, because i had broken battery but i replaced it, battery was re-programmed, there is only one message about the glows but i guess it's unrelated to the case).
Sound does not work for anything: Nav, telephone, radio, media.
I have 4F0 035 056 A unit in the trunk, I've checked, there is no water in the trunk. As far as i know, this is Radio AND amplifier module, radio "works" when there is no sound, i can read RDS datatext and switch between stations. All MMI options works properly.
After few minutes i can hear some pops and craclings from speakers (it last no more than 1-2 seconds) then everything works correclty). If I park the car after the long ride, it will work correctly once i get back. After short ride it might not work.
I wonder if there is any relay that provides power to the amplifier inside the unit, or i have cold solder somewhere? It looks like one.
Can you give me any clues or hints? I can solder even small SMD parts, so that is not an issue, but i need to know where to start
Old 02-21-2018, 12:52 PM
hrc4u's Avatar
without any vcds log we are only guessing...try to get a log if u know someone with vcds!
/H
Old 02-21-2018, 09:41 PM
Jorgos's Avatar
/H
as i said: no errors in vcds.
Old 02-22-2018, 02:52 AM
hrc4u's Avatar
Ops my bad! Missed that!
Hmm.. Haven't I seen something about sound issues when cold in either in an tsb or tpi.. Hmm..
Will take a look if I'll find anything later today..
/H
Old 02-22-2018, 03:00 AM
Jorgos's Avatar
I've checked and there is Quadlock in the trunk, it looks like two ISO plugs, Is it classic ISO? I wanted to check if all wires are correct (if there is any mute signal or something)?
Old 02-22-2018, 11:49 AM
hrc4u's Avatar
you have Bose?
Old 02-22-2018, 12:51 PM
Jorgos's Avatar
you have Bose?
No. Normal 10 speakers DSP
Old 02-28-2018, 07:23 AM
Sallad's Avatar
I have the Bose system in mine, and if the night gets colder than -10c deg, the speakers will screech and pop for a few mins, then no sound until I start up again... I think the amp just doesn’t like to get cold.
IknowHuhA6
A6 (C7 Platform) Discussion
31
03-12-2021 10:42 AM
jasonscott77
05-06-2016 06:36 AM
twaudiA6
01-14-2014 01:39 AM
elcid09au06xha
02-15-2010 05:41 PM
geek95
07-24-2005 03:58 PM
Quick Reply: No audio output when it is cold
