A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
P2006 & P2070 Codes
Old Mar 2, 2019 | 01:52 PM
  #11
Ronnie Eaton's Avatar
Originally Posted by A6Gary
Use a vacuum pump to check the actuator of each lower intake manifold, and the vacuum lines. I had a failed actuator on my '06 A6 Avant that caused me to replace the lower manifold assembly (the actuator is not sold separately).
Hello, sorry to resurrect but the thread just stopped. I am having similar issues to the previous guy.
P2070 and P2404
No vacuum leak anywhere... I’ve checked with a vacuum pump.
Taken the upper plenum off and the flaps seem to be on the correct side of the divider
How can you tell if it’s a failed actuator? Do I pull a vacuum with a pump directly to the line with the actuator? What am I looking for to tell me either it’s good or not?
Thanks for any info
Old Mar 2, 2019 | 03:33 PM
  #12
I went out and watched the flaps as I applied vacuum. They both seem to be working without binding. They both start opening around 7in.Hg of vacuum and are completely open around 14in.Hg of vacuum. Again, I have checked every line I can find for vacuum leaks by applying a vacuum and watching for any drop; there is no drop in any of the lines. Could there be something wrong with the Intake Manifold Tuning (IMT) Valve Position Sensor?
andysprague
Jun 22, 2007 10:33 AM
2001S4ICS
Nov 14, 2006 07:21 AM
CorrupTT
Aug 20, 2004 01:15 PM
Bob W.
May 30, 2003 10:21 AM
