A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
S6 Transmission Slipping?
Old 10-07-2012, 08:19 AM
slicksic's Avatar
Default S6 Transmission Slipping?
Hey guys,
have been noticing lately that when I punch it, the tranny would downshift, rpms would rise, then they would drop about 200rpms before the car would start moving. If anyone with an s6 or even a6 could please let me know if this happens to them as well it would be greatly appreciated.
It usually happens cruising at about 50mp/h (90 km/h), I would put my foot down (about half to 3/4 of the way down) to pass, the tranny would downshift 2 gears (for example, would bring the rpms to 4500), then the rpms would drop to about 4300 before starting to climb again. Just wondering if this is the start of tranny slipping, or maybe just the engine blipping the throttle for downshift?
Any help would be appreciated.
Old 10-07-2012, 09:57 AM
CHIO's Avatar
walk in front of the car and face away and yell out loud!!! "Audi if my tranny is going let me have it now"!! repeat over and over
Old 10-08-2012, 06:35 AM
newa6er's Avatar
I'm no tranny expert but my last BMW had tranny slip, the so called "lifetime fluid" BS. Anyway, even with the slightest slip the tranny would detect a fault and go into limp mode. If you have a VC see if it stored any faults. If the tranny is not slipping, your car might need to have the throttle and/or tranny tuned and setup properly. I have an A6 not a S6 and after changing tranny fluid and doing an adaptive throttle reset my tranny feels much different, there was a little lag which is now gone. Good luck...
Old 10-09-2012, 11:33 AM
2008A6's Avatar
My S6 does not hesitate, once it downshifts..
Old 10-12-2012, 07:48 AM
slicksic's Avatar
Could anyone else please check confirm?
Also noticed that when cruising in 6th gear at low speeds (rpm at around 1500), I could slowly press harder and harder on the gas until it "downshifted", the rpms would jump to about 2000rpm but would still indicate 6th gear...
Old 10-12-2012, 09:03 AM
SchwarzS6's Avatar
That is normal. It is the result of the torque converter unlocking. If you put it in Tip mode that should not happen.
Old 10-12-2012, 09:36 AM
uberwgn's Avatar
Our car certainly does the same...it's just the lock-up torque converter un-locking (as noted by Schwarz). It was noticeable in this car for some reason.
Old 10-12-2012, 10:26 AM
2008A6's Avatar
As others confirmed, that's normal. You'd have to punch it a bit harder for it to truly shift gears.
Old 10-19-2012, 09:43 PM
slicksic's Avatar
Thanks everyone for all the input, makes me feel a little bit better. Will change the trans fluid and report back, hopefully will help with the 2-1 downshift if anything.
quattrokid98A4
03-03-2007 12:59 PM
mbquattro
11-01-2005 04:09 AM
germantoy
Audi Original "S" Cars
12-11-2003 07:19 AM
quattro920
08-28-2002 10:14 AM
Avant 6
Audi 100 / A6 (C4 Platform)
07-09-2002 06:29 AM
Quick Reply: S6 Transmission Slipping?
