Upper Injector O-ring for the 3.2fsi?
Greetings!
i need to pull fuel rails soon..
anyone have part nr for the top blue O-ring on injectors? or do i really need to buy the whole injector seal kit? :/
cheers!/H
cheers!/H
Unfortunately, the blue O-ring is not sold separately, so you need to purchase the complete seal set for each injector. That is what I had to do when I had to replace one of the lower intake manifolds. And since I had to do that, I also did a carbon cleaning on both banks. So, I purchased (6) seal sets, and only used the blue O-ring from each set.
here in Sweden they are like 30$ /pc...crap crap
cheers/H
Yes, I purchased the OEM seal kit, P/N 06E-998-907-G, for www.genunineaudiparts.com, which sells the kit for $26.04 ea. I also checked a non-dealer supplier, and they sell the same OEM kit for $46.
quick word of advice from someone who just went through this... I wasted 46 dollars a piece on the rebuild kits a few months ago... well turns out i needed 2 new injectors.... If i hadn't wasted all that money on seals, i could have afforded to buy all 6 injectors new. I got them from all eurpoean in detroit michigan and paid about 120 a piece for my injectors... if I had to do it over again I would seriously consider just getting new injectors as they include the seals, the only thing they don't come with is the metal brackets that are included in the rebuild kits but most the time you can reuse those.
anyway the rebuild kits part number is 06E 906 036 Cinjection valve
also use:06E 998 907
if you want to just get new orings, there is a company here in toledo that I've been able to get any seal i've ever needed from... they are called Zatcoff seals located in Maumee Ohio however, they are nationwide and you could call them and get someone to help you out probably... their website is https://www.zatkoff.com/
The part number for the ORING only is 035 906 149 A however, it isn't available from audi but it is from other after market companies such as ECS tuning...
If you need part numbers you can access an ETKA clone online at this link: https://audi.7zap.com/en/usa/audi+a6...?vin=undefined
(that will take you direct to fuel rail and assemblies for 3.2 BKH engine)
are this o-ring installed in any cars that have High pressure injectors?
cheers/H
interesting..
went thru my etka and VW..
found this on a Touareg...
06A906145 or WHT005422B
this could be the holy graal!? =)
example site:
https://www.eeuroparts.com/Parts/811...ing-06A906145/
edit:..crap seems to be low pressure injectors when investigated more.. :/
example site:
I wish I had that O-ring seal part number when I changed that lower intake assembly, would have saved me more than a $100. Funny, when I entered that part number to the on-line dealer, he sells it separately for more than $22 less that the repair kit.
