2016 Audi A7 Hidden Menu Access
Old Feb 7, 2020 | 07:01 PM
spencer@tychecompany.com's Avatar
Default 2016 Audi A7 Hidden Menu Access
Thanks in advance for any and all suggestions!
Just joined this forum as I recently purchased a 2016 Audi A7 and immediately went out and purchased a VCDS interface to set it up for my personal taste.
I have read a bit here and on other forums and still cannot make the hidden green menu appear.
I've tried the steps below so far using HEX-V2 interface, VCDS and MMI:
1. Select 5F - Information Elect.
2. Select Security Access and entered S12345 password - the security code was accepted
3. Select Adaptation 10
4. Change the adaptation channel filter to 'devel', select 'IDE02122 Developer mode', set new channel value to activated and save - IDE02122 shows as activated when reloaded
5. Reboot MMI - this worked, as MMI the display went black and then reloaded
6. Hold down various button sequences which did not work
o NAV/CAR and RADIO buttons for 5 seconds
o NAV/CAR and MEDIA buttons for 5 seconds
o BACK and LOWER LEFT SOFT key for 5 seconds
Not sure what else to try.
Is there something else which needs to be done with VCDS before attempting to bring up the green menu?
Can anyone with a 2016 A7 comment as to the accuracy of any of the green menu button sequences?
Results of a VCDS auto-scan are below:
Code:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3B 3C 42 44 46 52 53 55
5F 62 6C 6D 72 8F 90
VIN: WAUWGAFC1GN115634 Mileage: 46194km-28703miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
Address 01: Engine (J623-CREC) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G2 907 551 A HW: 4H2 907 551 A
Component: 3.0l V6 TFSI H10 0004
Revision: --H10---
Coding: 1A2A00340526010D3000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0214G2907551A 002001
ROD: EV_ECM30TFS0214G2907551A_002.rod
VCID: 290FFBBBF9768E1FBE9-807C
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 927 158 AM HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H19 1004
Revision: --H19---
Coding: 000001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002022
ROD: EV_TCMAL551211_002_AU48.rod
VCID: 79AFEBFB4956FE9F8E9-802C
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Revision: -------- Serial number: --------------
Coding: 44A7964322E569C21B00
ASAM Dataset: EV_ESP9BOSCHAU57X 004018
ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
VCID: 41DF431B6106665F869-8014
5 Faults Found:
124416 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
[Ldm_ApbFailureState]
Intermittent - Not Confirmed - Tested Since Memory Clear
154624 - Tire Pressure Warning
C102D 00 [032] - -
154880 - Tire Pressure Warning
C102D 00 [032] - -
155136 - Tire Pressure Warning
C102D 00 [032] - -
155392 - Tire Pressure Warning
C102D 00 [032] - -
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 GR HW: 4H0 907 064 GR
Component: BCM2 2.0 H37 0572
Revision: 00002001
Coding: 0DAA6F4E000000000000
VCID: 7F5B05E357F2D0AFB0D-802A
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 3215000180084009
1 Fault Found:
00956 - Key 2
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 9
Mileage: 45757 km
Time Indication: 0
Date: 2020.01.20
Time: 07:49:54
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Component: KLIMA 4 ZONEN H14 0112
Serial number: 13111500040876
Coding: 66033178490000
ASAM Dataset: EV_AirCondiComfoUDS 003008
ROD: EV_AirCondiComfoUDS_003.rod
VCID: 6393A993DBDA144FB45-8036
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DM HW: 4H0 907 063 AM
Component: BCM1 2.0 H20 0311
Revision: 21020001 Serial number: 00001194310801
Coding: 01050011043C9FE08101488780007800CF9CC208A60802218000081C7110150200600034030000
VCID: 76B5E0C778C891E7E3B-8022
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 150919 H38 0080
Serial number: 151017072444
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 60922643
Coding: 02006E
Subsystem 3 - Part No SW: 4G0 941 531 AL HW: 4G0 941 531 AL
Component: E1 - LDS H07 0044
Serial number: 16 11 2015 00001202
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 00000000095Z021A18BE
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA121911000016247105
Coding: 020300
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 808989D7000000000001
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4G0 959 655 B HW: 4G0 959 655 B
Component: Airbag10.43 H62 0086
Revision: -------- Serial number: 003G0002R8LY
Coding: 303331333131303134394A55304C34473853
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 34311ACF2EB4C3F71DF-8060
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H11 0046
Serial number: 6940000Y150001ET330N
Crash sensor for side airbag: driver side:
Serial number: 3575HRB400G551R05HB.
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB40693LHKE30UV
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB40613KDM8GODT
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB405V3KDM6DGG6
Crash sensor for front airbag: driver side:
Serial number: 3554VRB400U554Q2B9R.
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB40165558A81JU
1 Fault Found:
9444612 - Safety belt switch - passenger side
B101D 04 [136] - Internal System Fault
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 7
Mileage: 44105 km
Date: 2019.11.28
Time: 12:11:03
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862OKE0009P
Coding: 000034
VCID: 3B2331F3036A0C8FDC5-806E
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0010
Serial number: 01 10 2015 D0000044
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 986 P HW: 4G8 920 986 P
Component: TBenUsa H11 0106
Revision: 08001098 Serial number: 658171115596014
Coding: 03EF01060B43D705020100
ASAM Dataset: EV_RBD4K 004055
ROD: EV_RBD4K_AU57.rod
VCID: 45D7570B752E4A7FBA1-8010
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000002048713
Coding: C0CD073010
ASAM Dataset: EV_GatewPkoUDS 001028
ROD: EV_GatewPkoUDS_001_AU57.rod
VCID: 3B2331F303EA0C8FDC5-806E
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 5729868203
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 15073000000000000224
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 12111500040912
Coding: 20
ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
ROD: EV_ClimaContrUnitRearUDS_003.rod
VCID: 3D273FEB1DFE02BFE21-8068
1 Fault Found:
0075 - Button or Switch in Operating Unit
B10C7 07 [008] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 43
Mileage: 46146 km
Date: 2020.02.01
Time: 11:34:40
Outside air temperature: 3.5 °C
Left rear vent temperature: 47.5 °C
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000175063671
Coding: 00581B0000006001000001010101102030303232203232
VCID: 77ABEDC37FC2E8EFF8D-8022
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720LKP7X
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 333319D32BBAC4CF045-8066
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 4G0 907 566 M HW: 4H0 907 566 F
Component: SWA Master H07 0060
Serial number: 0383852004
Coding: 040211
ASAM Dataset: EV_LaneChangAssis 001028
ROD: EV_LaneChangAssis_AU21.rod
VCID: 392F2BFB09D63E9FCE9-806C
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 4G0 907 568 M HW: 4H0 907 568 F
Component: SWA Slave H07 0060
Serial number: 0385979605
Coding: 040211
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0511
Coding: 011F57035E00628002000412
VCID: 47CB5D034FA2586F48D-8012
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H55 0202
Revision: 00000001 Serial number: 0000626355
Coding: 101000010001
Shop #: WSC 42494 002 1048576
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A2D34F70CD03587C73-806E
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0385845486
Coding: 0126063A20BAF08583B00A0402030D470000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000322953
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
Component: J245 PS40.402 H03 0004
Serial number: 0000FST000N2DGI00000
Coding: 101F02
Subsystem 4 - Part No SW: 4G8 959 252 A HW: 4G8 959 252
Component: HSP-SG H11 0031
Serial number: WA122232000016853135
Subsystem 5 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Serial number: 93677103
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0511
Coding: 011F57035E00628002000402
VCID: 46D5500748A84167B3B-8012
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001658127
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D070FABCD9E923F521-8078
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 E HW: 7P6 907 357 B
Component: MxB-ECU 001 0100
Coding: 05FA021122200400
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
Led Headlamp Powermodule Left:
Subsystem 1 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7570
Coding: E02000
Led Headlamp Powermodule Right:
Subsystem 2 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7570
Coding: E02000
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 025 B HW: 4G1 035 025
Component: MU-H-LNS-US 043 0387
Serial number: A278K0FB019835
Coding: 017503020000000013220002041A00102F000CE5F17001047E
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
VCID: 1D67DF6BBD3E62BFC21-8048
Data medium:
Subsystem 1 - Part No SW: V03 959 801 PS HW: -----------
Component: NAR 2018 --- 0063
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9FY803ER8
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G1 919 610 F HW: 4G1 919 610 F
Component: E380 BDT C7 H20 0250
Serial number: 90349OKB000XP
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 3006
1 Fault Found:
0020 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 23
Mileage: 40527 km
Date: 2019.04.30
Time: 08:18:18
Voltage terminal 30: 14.9 V
Satellite radio tuner status-Satellite radio antenna status: Electrical OK
Satellite radio tuner status-Channel selection for satellite radio: 0
Satellite radio tuner status-Audio Signal: Available
Satellite radio tuner status-Antenna current: 0 mA
Satellite radio tuner status-Reception quality: optimum_signal
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0511
Coding: 010F17024000628002000002
VCID: 49CF5B3B59B6AE1F5E9-801C
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 HW: 4M0 980 556
Component: RVC Compact H08 0140
Coding: 0275000102002003000040
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
ROD: EV_CamSysRVRVCPANAAU57X_001_AU57.rod
VCID: 78A9EEFF725CE797F17-802C
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G8 959 107 T HW: 4G8 959 107 J
Component: HDSG-Modul H14 0049
Revision: 12014001 Serial number: 308500171
Coding: 0A3305C122
ASAM Dataset: EV_HDSGAu573 001022
ROD: EV_HDSGAu571.rod
VCID: 46D5500748284167B3B-8012
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0511
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H14 0080
Coding: 0006E008031F0300070308014244CA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313F13DBD1A6F6DF769-8064
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H14 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 323D1CD7D4A0CDC70F3-8066
End----(Elapsed Time: 02:14, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Thanks again for any and all suggestions
Old Feb 8, 2020 | 03:17 PM
fkaufman's Avatar
On my 2015 A7 TDI I had to activate the green menu, using my ODBEleven device. There is a menu item on it to do that. After doing that, I can now get into the green menu by holding the buttons down. I could not do that before the activation process.
kingcezar1992
A6 (C7 Platform) Discussion
13
Mar 5, 2020 08:44 AM
Sawdusty Dan
Feb 10, 2020 07:10 AM
Klemen Nemivsek
VAG-COM Discussion
Nov 14, 2017 06:43 AM
njajr
VAG-COM Discussion
Aug 26, 2016 10:57 AM
selp
Audi A3 / S3 / RS 3 MKII
Dec 13, 2015 04:43 PM
