A7 Coolant temp too high and Coolant system fault
Hi all, I stopped my 2012 A7 at shop 2 days ago for 2-3 minutes with engine ON and AC ON, as soon as i come back saw on my dashboard Coolant system fault, i tried to move the car to better place to park and Cooland Temperature too high error has pleased me instantly, The gauge was really ar the red line , and hot coolant leaked from the expension tank... lately i tried to inspect the fault myself and found out that Fans won't start even coolant temp is at the middle normal level and with AC on... I am on vacation now and haven't been at the workshop yet to scan codes,but what shall i expect from this Fault? Fan unit replacement? Fan fuse dead? Thermostat? (I don't think). Whats the common issues for these cars?
Thanks
Thanks
Hi Had the same issue earlier in the summer. Turned out to be the fuses for the fans....See post here:
https://www.audiworld.com/forums/a6-.../#post25177480
Coolant System Fault/ Both fans inactive
I have the same issue? If it’s a possibly thermostat issue what route did you go repairing it? My mechanic is saying I need two new fans he changed the fuse still no activity from the fans
Mr Paul [T-28]
11-21-2004 06:42 AM
