A7 TDI Brake Rotors and Pads
I plan to replace the rotors and pads now and am looking for a quiet replacement. I am not as concerned as many about the looks of the rotors (dimples, holes, slots). The manufacturers indicate the slots help with cooling and initial bite - the the dimples and holes are generally just for aesthetic purposes.
I have read many of the posts. Everyone has a different goal when replacing brakes as many track their cars or drive steep grades or mountain roads routinely. My goals are for quiet brakes on a daily driver that is not pushed at all.
I have talked to Centric, StopTech, and Adams Rotors. I know that Adams is well thought of in this forum. I asked them why I would choose their slotted rotors over StopTech slotted rotors. They told me they were custom and cooler looking with special pattern designs. They generally sell the Centic PosiQuiet pads with their rotors.
I believe I am leaning towards the StopTech rotors (126.33138SL & 126.3313SR) with the StopTech pads (308.13221). StopTech has told me these are the same pads as the Centric PosiQuiet 104.13221.
Does anyone have suggestions for a quieter setup?
Any suggestions would be appreciated.
If you want dust free then get the Gold which are ceramic and not much more. As for rotors, as long as the rotors you have are not warped and are above the minimum thickness requirements then there is no reason to replace them. For a street car solid rotors are what you need. Cross drilled, dimpled, or slotted are just bling on a street car. Even for a track car they are marginally better for stopping power. Under heavy braking track conditions the cross drilled can actually overheat and crack/break. If you have ever watched racing you will see the rotors glowing red on a heavy brake track and even with the solid rotors they can still have failures.
