AC Compressor Replacement
Old Sep 3, 2020 | 04:10 PM
grenadianaudi's Avatar
Default AC Compressor Replacement
I am replacing my AC compressor that had an issue and I purchased the dowel sleeves (03L-260-817) to insert in the bolt mount holes between the compressor and the mounting bracket but the sleeves do not fit. Do I need a special tool to press them in or should it slide in easily? Has anyone here skipped using them? Will I really have an issue lining up the compressor without the sleeves? I junked my old compressor and do not recall if there were sleeves in it.
Old Sep 3, 2020 | 07:13 PM
Valpo A7's Avatar
I just removed my compressor while the engine was out and I don’t remember any sleeves. I can check my Erwin manual in the morning and I can check on the compressor next time in the garage.
edit. I looked up the sleeves on the web so I know what to look for on the car
Old Sep 5, 2020 | 04:45 AM
Ok thank you! That would be great!
Old Sep 5, 2020 | 09:11 AM
Valpo A7's Avatar
Sleeves look to be pressed into the compressor housing. When I tightened the bolts they just sucked up in place on the bracket they mount into
Old Sep 24, 2020 | 10:17 AM
Thanks for the help. I went ahead and installed the compressor without the sleeves. Just bolted it as tight as I could. Hopefully it stays put
Old Sep 24, 2020 | 06:00 PM
fkaufman's Avatar
That may not be a very good idea! The sleeves are there for a reason.
yepodm
Jun 14, 2020 11:35 PM
ModifiedA4
Dec 9, 2004 06:50 AM
BPUKiller
Mar 10, 2004 07:57 AM
C32
Sep 19, 2003 12:48 PM
KAZ
Jan 22, 1999 05:47 AM
