Audi A7 AAS Dynamic Problem
A month ago I bought a Audi A7 11' in Germany.
After a few days I realized that are some problems with the AAS in dynamic mode.
When I'm leaving my car and come back 1 or 2 hours later, the rear of my car is going down. It seems like that the compressor has some problems.
It is not my first day to work with vcds, but the error memory is empty.
When I am checking the "Stellglieddiagnose" it seems that everything is o.k.
I asked the guy where I bought my car, he tell me that is normal. I asked Audi and they tell me the same answer.
Now I'm driving with 19' rims, but in Summer with 20' rims, I don't think that will go well.
In other modes like comfort or automatic I don't have this problem.
I'm sure that is 100% not normally.
A minute later after I close my car, the compressor is working a little bit and the rear is going down about 1cm. After that the air escapes slowly.
Can someone help me?
The behavior is that if I let the car on normal mode the whole back of the car will go down in a few hours.
If I lift (raise) the car suspension before turn it off it will stay lifted.
Might be the air springs?
Thanks.
Address 34: Level Control (J197) Labels: 4G0-907-553.clb
Part No SW: 4G0 907 553 B HW: 4G0 907 553
Component: LUFE-DAEMPFER H17 0778
Coding: 008002
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_AirSuspe 003022
ROD: EV_AirSuspe_AU57.rod
VCID: 2A4312F31CFFD0D261C404D-807F
1 Fault Found:
677394 - Air Spring or Air Line; Rear Left
C1149 07 [008] - Mechanical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 134359 km
Date: 2016.09.10
Time: 12:58:12
