Keyless Entry Not Working
Old Feb 11, 2015 | 07:55 AM
sniperdm55's Avatar
Default Keyless Entry Not Working
The keyless entry isn't working, I have to unlock the doors and trunk by using the key fob. When I get out I am able to lock the car by pushing the thingy on the handle. It's not a big deal but I like the keyless entry. The batteries are only a few months old. Any other solutions??
Old Feb 11, 2015 | 07:59 AM
fkaufman's Avatar
Do you have the same issue with both key fobs?
Old Feb 11, 2015 | 08:00 AM
sniperdm55's Avatar
Yes both fobs aren't working. The keyless entry will work if the car is locked for approximately 5 mins or less but any longer then that it will not work.
Old Feb 11, 2015 | 08:05 AM
fkaufman's Avatar
The computer system/MMI etc. is powered and still running most functions for about 5 minutes after you shut the car down, it then turns most functions off. One of the functions that supposed to stay on indefinitely is the keyless entry sensing. Looks like it turns off in your case. Reloading the software should cure it.
Old Feb 24, 2015 | 02:01 PM
sniperdm55's Avatar
I did a hard reset and that didn't fix it. I finally took it to the dealer and after 1 hour of running diagnostics it turns out that the car battery was almost completely depleted. When the battery is very low and almost depleted it shuts everything off to conserve what power is left. You all should be aware of this since there is no other way to determine the battery level that I know of.
ndjano
Apr 12, 2006 09:19 AM
david9962000
Nov 25, 2005 07:17 AM
harinder
Jan 6, 2002 03:55 PM
allestraße
Audi allroad
Dec 17, 2001 04:29 PM
Stang Guy
Mar 19, 2001 07:27 AM
