MMI startup
Old Oct 7, 2013 | 02:17 PM
ericbergan's Avatar
Default MMI startup
So, in measuring the MMI startup in my new A7, in the morning, the Nav takes 30 seconds, music starts playing off the SD in 80 seconds, and Google Earth comes in at 130 seconds.
But, if the car is shut down for <15 minutes, it all comes up immediately.
If the car is shut down for ~30 minutes, Nav is instant, but music is 60 seconds, and Google Earth is 84 seconds.
After an hour of shutdown, it's the same as overnight.
Is there any way (vag-com?) to push the "sleep" versus "shutdown" from <60 minutes to a few hours?
BTW, this is all with MMI version 715.
Thoughts?
eric
Old Oct 7, 2013 | 05:23 PM
snagitseven's Avatar
Super Moderator
I haven't seen where anyone has discussed this or discovered a way in Vag-Com to change it and Audi has been using this "two step" sleep programming for several years. The MMI is tied to other systems like door locks, etc. for the "deep sleep" mode whose purpose is designed to save battery life (especially useful in colder climes). With all of the electronic systems included these days, they place an increased current draw compared to cars from several years ago.
Old Oct 8, 2013 | 11:32 AM
ericbergan's Avatar
Given my car has Start/Stop, and hence a beefier battery, I suspect it probably could "sleep" for a few hours without danger.
Still, sounds like it's not been an issue for Audi, so not likely to see any kind of change.
Old Oct 8, 2013 | 11:53 AM
Super Moderator
I don't think it's a matter of the (supposed) larger "stop/start" alternator being theoretically better at charging the battery but longevity of the battery itself.
The MMI system "cold" boot times can be a bit annoying, especially with the Audi Connect features, but I can live with it.
Old Oct 8, 2013 | 05:42 PM
msizzle's Avatar
I find it very frustrating as well, Also does your MMI ask you about wifi and google earth over and over again?? Why can't it be a permanent yes??
Old Oct 8, 2013 | 07:16 PM
Super Moderator
https://www.audiworld.com/forums/sho...19&postcount=4
nath339
Nov 7, 2015 03:29 AM
Jehu8
15
Oct 14, 2015 07:10 PM
geter
Sep 29, 2015 01:39 AM
austonwerner4
Sep 27, 2015 08:25 AM
cobrar97
Q5/SQ5 MKI (8R) Discussion
Sep 25, 2015 01:17 PM
