Seeking advise for a purchase
Hi, I have been looking to get a newer A7 or an older S7. Recently, I came across a decent S7 but VAGCOM returned the following fault codes.
Am I correct that this S7 will need:
1) motor mount fix (>$2000?)
2) potential air suspension issue (>$1000?)
3) might need to replace battery ($200?)
Thanks!
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 AM HW: 4G0 820 043 AM
Component: KLIMA 4 ZONEN H14 0093
Serial number: 29111300040056
Coding: 680320785D
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_AirCondiComfoUDS 004003
ROD: EV_AirCondiComfoUDS_004.rod
VCID: 6ADBAE4D8D20A21A63-803E
1 Fault Found:
0386 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 224
Voltage terminal 30: 11.35 V
Outside air temperature: 11.0 °C
Energy management deactivation stage: 1
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Component: J533--Gateway H13 0050
Revision: -------- Serial number: 00000001188418
Coding: 00E1034800
ASAM Dataset: EV_GatewPkoUDS 001019
ROD: EV_GatewPkoUDS_001_AU57.rod
VCID: 72EBB62DA5F06ADADB-8026
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 4972481903
1 Fault Found:
12291 - Energy Management Active
U140B 00 [008] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 224
Voltage terminal 30: 11.3 V
Voltage terminal 15: 11.4 V
Control Module temperature: 16 °C
System status: Terminal 15 on
IN ESP_standstill flag: standstill detected
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 1
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H18 0782
Coding: 008002
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
VCID: 2E53625D71480E3A7F-807A
1 Fault Found:
403200 - Function Shut-Off Active
C10C8 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 220
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 HW: 4H0 907 145
Component: AEM - LEAR H07 0006
Revision: 00001001 Serial number: 97809002907800
ASAM Dataset: EV_AEMLearAU64X 002014
ROD: EV_AEMLearAU64X_AU57.rod
VCID: 66C3DA7D9938867A47-8032
1 Fault Found:
1294 - Actuator 1 for Drivetrain Mounts
C1131 07 [009] - Mechanical Failure
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 180
Thanks!
Thanks!
Coding: 680320785D
1 Fault Found:
B10CD 00 [008] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 224
Coding: 00E1034800
1 Fault Found:
U140B 00 [008] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 224
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 1
Coding: 008002
1 Fault Found:
C10C8 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 220
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 180
Thanks!
Rally_nutcase_1982
Wheels & Tires Discussion
03-26-2006 06:42 PM
Rally_nutcase_1982
Audi allroad
02-10-2006 08:36 PM
TCD
06-04-2005 06:35 AM
JakeTT
06-21-2000 09:29 PM
