vag-com/VCDS A7
Old Oct 10, 2013 | 03:23 PM
aquarian's Avatar
Default vag-com/VCDS A7
Lately my nav screen has been acting strange when retracting while the car is shutting down. It shudders/vibrates occasionally.
Ran the scan and found:
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 746 HW: 4G0 035 746
Component: H-BNT-NA H48 0294
Revision: -------- Serial number: 031CK0B7502813
Coding: 090200040003E1EF55128B2E000000031000010000000000
Shop #: WSC 02391 785 00200
VCID: E4CD3249E7401E9
Subsystem 1 - Part No: 8R0 060 884 AC
Component: NAR 2011 0503
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Subsystem 3 - Part No SW: 4G1 919 612 L HW: 4G1 919 612 L
Component: E380 BDT C7 H08 0120
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
1 Fault Found:
03787 - Rotation Mechanism for Display Module Front
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 6
Fault Frequency: 1
Reset counter: 229
Mileage: 18226 km
Time Indication: 0
Date: 2013.09.12
Time: 18:54:36
Freeze Frame:
Voltage: 12.00 V
Has anyone experienced as well?
Old Oct 10, 2013 | 04:23 PM
snagitseven's Avatar
Super Moderator
When the first A8s came out with the motorized screens awhile back, after a period of time the plastic gear would break. It's been reported that Audi redesigned the part (metal?) since so it's likely not your issue. Seems to be an intermittent connection somewhere judging from the fault report. I may have missed something but I haven't seen anything over on the A6/S6 forums on the screen yet. It's warranty time.
Old Oct 10, 2013 | 07:02 PM
aquarian's Avatar
Thanks. I haven't seen anyone posted anything similar. It doesn't bother me that much, maybe I will remind the dealer when I bring the car in for service.... Or I can just take out the screen and see what's going on behind the screen. I do have Elsawin...
Old Oct 11, 2013 | 04:23 AM
BasicSlvr's Avatar
Yup, experienced this issue on my D3 A8. It did not throw a code when it occurred.
Old Oct 11, 2013 | 04:32 AM
fkaufman's Avatar
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 229
Mileage: 18226 km
Time Indication: 0
Date: 2013.09.12
Time: 18:54:36
Freeze Frame:
Voltage: 12.00 V
I had this happen on my 2012 A7 about a year ago. Took it in for service, they reloaded the software (so I was told) and it has been fine ever since.
Old Oct 11, 2013 | 07:31 AM
viks07's Avatar
I have experienced the same thing on mine, on the way up the screen is fine, but on the way down the screen always judders.
Took the car in the Audi and show them a few rattles, including: -
- Indie the driver door (near the metal door opening handle)
- Instrument cluster sometimes squeaks depending on road conditions
- Screen issue described here
- and a few other things
And they ordered a few parts and fixed them all.
If I have the parts list I will post later.
Old Oct 21, 2013 | 08:09 AM
aquarian's Avatar
Is it possible to lock the car from the outside while the engine is running using VCDS?
Also, has anyone figured out how to activate the backup camera at higher speed, much like video in motion?
Old Oct 31, 2013 | 09:59 AM
jaxsully's Avatar
i have experience this only once since I got my '13 in March. I just reset the MMI and did not have any more issues, not sure if there is a correlation or not.
Sully
Old Jun 18, 2014 | 06:20 AM
VacationCharmA7's Avatar
Default Audi A7 Display
My A7 display used to studder coming out and back into the dash. I took it to the dealership while it was under warrenty and they replaced it for free. They also did a software update. The service guy said they were aware of the issue with other vehicles.
hebert12lax
VAG-COM Discussion
Jun 25, 2015 03:04 PM
StanAccy
A4 (B8 Platform) Discussion
11
May 20, 2014 04:21 PM
Andyly
Q7 MK 1 Discussion
Apr 4, 2014 03:14 AM
ModestW12
Aug 22, 2012 08:30 PM
ModestW12
Aug 10, 2011 05:54 PM
