Winter Setup
Winter Setup
Dropping down to 18" from the stock 19" is about as far along as I've gotten so far in the process - but then it still is only August
Some of the A6 guys say that they are using 17" wheels. Post #12
https://www.audiworld.com/forums/sho....php?t=2831349
Winter Setup for Portland
I looked at 17s because of recommendations from folks that deal with deep snow that skinnier is better (and the tires are a lot cheaper), but decided on just dropping to 18s after convincing myself that size is the best compromise between wet handling and ice/snow traction. The jury is also out on whether 17s will fit--a couple tire shops, including Tire Rack, said no, but dealer and others said they'd fit. At the end of the day, I think 18s are best for my situation anyway.
I've pretty much decided on Hartmann wheels, and while I'd love to get a used set, I haven't had any luck so far.
For tires, I've narrowed it down to Nokian Hakkapellita R or Michelin xIce 3, both ice and snow tires rather than performance snows, since Portland hills and zero-friction ice/slush is the nastiest, slickest combination I've ever seen.
Where in the NW are you located? What tires are you considering?
That's what we get to deal with in Portland a few days a year--black ice and/or freezing rain and/or snow right around freezing. There's nothing slicker. I'm very interested to see if the ice and snow tires can deal with it. A lot of people here use studs, but I really don't want the handling or noise issues when it's not bad out.
