"S"quirt Mode Enabled!
So we'll see if it will:
1) work
2) work, then blow up my car
3) become a paperweight
Paul, any what code should I enter for the new box? Unlike yours, this will come with a code for a diff. motor... Oh and where is the TCU located :-)
Thanks again for all of your experimentation, Mr. Neil Armstrong!
1. If coded to the A8, it won't go to the 7K redline.
2. The gearing is different on the A8 as compared to the S8, wonder if the ECU looks for different gear ratios.
So just code it to a S8 (mine worked on either S8 coding) before you drive it.
To get to it, open hood, drink beer, look at engine, drink beer, go to RH side of enginge compartment, drink beer, take off the electronics box cover....there is one screw in the back, you pop off a little cover in the plastic screen above it so you can get a long screw driver down into it.....or use an offset screw driver to get it off.....drink beer.
Take cover off, two screws to get the TCU out, take connector off, drink beer, unbolt four screws, mount new TCU, connect connector (forgot about drinking beer there) and install.
Recode (must be done with ignition on, engine not running) and check it out!
The TCU is the thing on the right in the picture, the black thing....
<img src="http://pictureposter.audiworld.com/22012/dsc03713.jpg">
Could you please tell me what the code is that I should use to re-program the TCU to S8 code?
THanks, Ed
So based on that, if you did not get a S8 TCU, I do not know if it could be coded to a S8....and if it didn't code to a S8, it would not have the redline of the S8, and maybe the gear ratios would be wrong.
You might want to reconsider if you can stop them from shipping it.....or I'm sure others with an 00 or 01 A8 or A8L would buy it off you if it does not work on your S8.
Keep us posted....
