100 octane
my D2 seems to like the new juice. any chance i'm doing damage with the higher octane?
I honestly do not know how high the A8's computer senses and compensates in the OTHER direction (for high octane gas) so I can't comment definitively.
One thing is for certain tho; the A8 knows what you put in the tank and changes the power output of the car via ignition timing to compensate.
I would be curious to know how paying $5 a gallon for 100 Octane fuel from the pump compares to adding Octane Booster to normal gas, when you want to get the same 100 Octane number.
My ignition timing runs at 26 deg of advance cruising at 65 mph; but at full throttle, ignition timing is only 2 deg of advance. If the timing is retarded less than 24 deg with 100 octane fuel, you're getting more power, and I could plug the numbers into my computer model of the 4.2L motor to calculate the gain.
The 11:1 compression ratio motor is certainly prone to pre-ignition/detonation. The computer model says max power is with 18 deg of advance at full throttle, and 16 deg of retard from this is a lot. The only question is how much of this retard is due to knock sensors.
Even if the 5valve S8 engine is probably burning faster then the old ABz 4valve it may be of interest to know that I run 28degrees advance at WOT on my Autronic controlled ABZ. This is without knock sensors.
This may have been a bit more timing then needed, the 'carbon ring' on the center ceramic is to far down to be seen). But I haven't had any detonation problems with it (also verified by reading the plugs).
My 2000 A8 pinged from day 1 on Washington's 92 octane. Octane booster only burned out the 02 sensors. The car was happiest when I was in Canada and could buy 95 octane, or mix unleaded racing into the tank. My '04 seems to have a better map, and adjusts better to lower octane fuel.
Robin
