1997 A8 Wont start after sitting 6 weeks
#11
I have the codes!
Hey everyone - I pulled all the codes from the car tonight. There's alot.
Tuesday,11,December,2007,21:32:00:51828
VAG-COM Version: Release 704.1
Data version: 20071016
Chassis Type: 4D - Audi A8 D2
Scan: 01 03 08 11 15 16 17 18 25 35 37 45 55 56 57 65 67 75 76 77
02
Address 01: Engine Labels: None
Part No: 4D0 907 557 D
Component: 4.2L V8/4V MOTR AT D05
Coding: 01273
Shop #: WSC 00000
3 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
18020 - Engine Control Module Incorrectly Coded
P1612 - 35-00 - -
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 35-10 - - - Intermittent
Readiness: N/A
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Part No: 8LO 862 257 B
Component: CV-Pump,Alarm, RC
Coding: 12172
Shop #: WSC 65535
8 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
Address 02: Auto Trans Labels: None
Part No: 4D0 927 156 K
Component: AG5 01L 4.2l4V RDW D32
Coding: 00011
Shop #: WSC 00000
2 Faults Found:
17114 - Gear Ratio Monitoring: Incorrect Gear Ratio
P0730 - 35-10 - - - Intermittent
17087 - Brake Switch (F): Electrical Malfunction
P0703 - 35-00 - -
End --------------------------------------------------------------------------------------------------
02
Coding: 01273
Shop #: WSC 00000
3 Faults Found:
P1612 - 35-00 - -
Readiness: N/A
Coding: 12172
Shop #: WSC 65535
8 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 00011
Shop #: WSC 00000
2 Faults Found:
P0703 - 35-00 - -
#12
I was able to pull the codes. Here is what I have.
02
Coding: 01273
Shop #: WSC 00000
3 Faults Found:
P1612 - 35-00 - -
Readiness: N/A
Coding: 12172
Shop #: WSC 65535
8 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 00011
Shop #: WSC 00000
2 Faults Found:
P0703 - 35-00 - -
02
Coding: 01273
Shop #: WSC 00000
3 Faults Found:
P1612 - 35-00 - -
Readiness: N/A
Coding: 12172
Shop #: WSC 65535
8 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 00011
Shop #: WSC 00000
2 Faults Found:
P0703 - 35-00 - -
Refs
12-18-2013 02:44 PM
