2001 S8
Old Jul 25, 2011 | 02:02 PM
jagman78's Avatar
Default 2001 S8
Occasionally my ECP and ABS lights come on together. I took the car to a mechanic and he vag-comed the car. He got a 01435 fault code. He told me that the possible causes are the brake pedal switch and the brake pressure sensor 1 (G201). We replaced the brake pedal switch and I still have the problem. Can anyone tell me where the brake pressure sensor is located and how to replace this sensor. Is this an expensive part that has to be purchased from the dealer?
Old Jul 25, 2011 | 06:46 PM
silverd2's Avatar
First "EPC" (electronic power control) is your fly-by-wire throttle...don't know if that's related directly with your problem, unless it's a wiring thing(?).
Bentley doesn't have much about the G201 sensor, but I found something about it in an Audi tech training manual...and it doesn't look good, if it is indeed your problem (see below). Look at the warning about removing it...BUT, I've repaired other items in the past that Audi tells their techs can't be disassembled, so it could be replaceable...I dunno.
Might be worth having your electric module on the side of the ABS hydraulic unit (G201 sensor is on pump under it) by Modulemaster ( http://www.modulemaster.com/en/index.php ), before going much further.
Not sure, but bad connections in this unit lead to many false warnings about the ABS hydraulic unit and related parts. May even want to check good plug connections on that unit and the plug for the G201 sensor(?)
G201.jpg?t=1311647654
I believe that's the sensor at the red arrows:
Old Jul 26, 2011 | 09:41 AM
silverd2's Avatar
[QUOTE=silverd2;24174386]First "EPC" (electronic power control) is your fly-by-wire throttle...don't know if that's related directly with your problem, unless it's a wiring thing(?)."
^^ Just to qualify that ^^ ...The EPC is actually directly tied to traction control. It's step #2 (throttle intervention) in stopping wheel spin...step #1 is ABS braking only the one spinning wheel and if both sides spin (front or rear), then power is cut back to the fly-by-wire throttle. Both are involved in the same system, but 2 different components of that system. Signals, however, are sent to both systems from individual ABS wheel sensors, which are what detects wheel spin (and which ones). It's just that the code you have doesn't normally point to the EPC...but all part of the same system, so could still be an electrical problem(?)
Old Jul 26, 2011 | 02:58 PM
tozoM8's Avatar
Tech Guru
I would re-calibrate the steering angle sensor and see if it fixes it.
Old Jul 27, 2011 | 02:06 PM
jagman78's Avatar
Tried that, didn't work.
Abcaudi
Audi allroad
12
Jul 28, 2023 10:25 AM
kcattorney
11
Sep 17, 2017 09:26 PM
gregp1962
Nov 2, 2005 03:32 PM
tk1780
Audi 100 / A6 (C4 Platform)
Sep 22, 2005 05:03 PM
chillzatl
Jan 3, 2003 04:49 PM
