97 A8 no heat
i disconnected both heater hoses at the firewall and sprayed the hose through to see if the valves were stuck closed or heater core blocked. water flowed through both directions fine. ran it for some time to make sure it wasn't just looping through the valves and back out. ran the hose through the heater hoses towards the engine in both directions, again water flowed out just fine.
i let the car get up to temp, revved the engine and opend the bleeders a few times and got fluid out of both bleeders. i had thought the lower heater hose had been getting hot, but it seems like its just heat soak from the exhaust temp. if i grab either heater hose on the other side of the firewall right after the bleeders, both hoses are stone cold. i can reach both hoses at the heater core connections and again, both stone cold.
i'm running out of ideas on what to check. hopefully i can get vag com to work, mbe there's a code somewhere that'll help out. if anyone has any ideas, feel free to let me know.
thanks in advance
The upper heater hose is the supply (in) hose for the heaters..it should always be as hot as any hose on a warm motor and full pressure any time it's running. That hose is connected to the pipe on the back of the motor, which is connected to the rear of both heads and is coolant exiting the motor...hottest coolant in the system, if all is correct.
I don't believe Vagcom will tell you much about this...sounds like a physical problem.
only other thing i could think of is the water pump isn't pumping, but thats pretty rare of a failure on any car.
This will cause the engine to run hotter the faster it's run, as the impeller will slip at higher rpm. Not sure if this is the problem in your case, but I wouldn't rule it out.
flushed out the after run pump and heater core again. only noted that only a small amount of hose pressure could be used, but the water came out fine and clean. i even disconnected the hose after the pump going to the heater core and water flowed fine through the pump and the core.
performed a chemical flush. this was the only time that the temp gauge went past the first big mark (about 1/4), gauge went to about half but no more. the flush said to fill with clean water and the flush chemical and run for 10mins after getting to temp. noted that the water boiled in the reservoir tank. both radiator hoses warm/hot, but both heater core hoses still cold.
let the engine cool down and then drained the flush/water mix from the radiator and both engine block drain plugs. topped back up with coolant and let get to temp.
for fun, i decided to disconnect the heater hoses at the firewall while the engine was running. at idle and with throttle, no coolant came out of either hose... i'm not sure that the t-stat opened yet, but water should still flow from the hoses right? definately not a good sign.
so this prolly means that the water pump isn't pumping right? i still don't think it is the headgaskets like the one shop thought. no coolant in oil or oil in coolant. plugs don't show any coolant burning, no overheating (tho i haven't driven it as i haven't got plates yet), no coolant smell from exhaust.
am running out of 40+ degree days to work on it. might have to get one of those turbo heaters or just wait till spring to replace the TB and water pump. i'm ok with doing that repair as the front right cam seal leaks like a siv when the engines running.
lemme know what u guys think. thanks again for all the advice
I would think that if the pump was seized, you'd be hearing it and smelling burning timing belt.
But, still...impeller failure is rare. Only in an astronomically high mileage American car, have I ever seen it...and that was corroded broken off metal blades.
Plastic impellers are not inherently defective or even less dependable than metal...seen em go 150K miles in perfect condition. Who knows? ...maybe someone else's past screw-up. Mixing other coolants with G-12 not only causes thick brown sludge to form, but is highly corrosive to plastics...I have seen that mistake lead to coolant leaks at plastic fittings in VW's.
Please take some pics when you get to the heart of the problem...sounds like it's time to look at that pump(?).
I replaced it, along with the timing belt and tensioner / idler, and it was fine. Prior to that, I had no heater, despite the coolant temperature rising at a steady 60 mph. At idle, the heater would blow lukewarm air, once I increased the rpm, it would go stone cold.
i can't feel flow in the heater hoses by hand. i think i can feel it in the radiator hose. i do notice coolant flowing from the small top hose going into the reservoir tho, increases when i up the RPM's, so i think there must be some water pumping action going on.
drove it for a couple miles today. engine temp never raised past the first big mark, but never got heat. drove it hard and easy, no change.
when i had the heater hoses connected and the drain plugs out, water flowed easily out. only trouble i had was when i tried to spray water towards the heater core, had to use very little pressure, even when i bypassed the after run pump. i'm guessing this is because of the restrictions of the thin tubes of the core assembly?
is it possible that someone may have done either an intake gasket or head gasket and swapped gasket sides covering up a coolant passage? i'm just not sure if that'd be the problem cuz it drains fine when i spray down both heater hoses towards the block.
frustrated... thanks again for everyones help and comments.
