A8 D2 4.2 PFL Engine fuel consumption off
Recently the fuel consumption values in instrument is very vrong.
When the car is on idle, and idling down a downhill it shows a very high value. It seems that its more correct when the RPM is increased.
Where to start.
Where to start.
Just to make clear, what is high value ?
I have a similar "problem" with my D2 4.2 tiptronic. As if have speed about 90 km/h and I lift my foot from the gas pedal the consumption (according to the dashboard view) is still about 4l/100km (have to convert that to mpg..) but if the speed is 110 km/h, lifting the gas pedal will drop the consumption 0. And it stays there till the speed has dropped to aprox 80km/h and then it starts to consume about 3-4L /100km even with foot off the gas pedal. I don't actually know if that is supposed to do that or is there some leak in the intake manifold of some other problem...
How is it working with everybody else ? Does the consuption drop to 0 when the throttle is closed and the motor is braking ?
Hey.
No Miles for me, kilometer here.
When driving in slow traffic and barely touching the gas pedal it will go up to 3-4l/100km. Even when foot off gas pedal it is very slow in getting the values down to 0,2-0,7L/100.
This was correct earlier this year.
The instant fuel reading is rarely believed by most D2 owners...the average readout is more consistent, but almost always reads too "optimistic" (plus 1-2 mpg) compared to actual fuel consumption.
Zero out the odometer and your average readout when you fill the tank, then calculate the actual fuel mileage (kilos, whatever) when you refill the tank (the ONLY accurate)...check that against the average readout.
You didn't get much response because no one really cares about or trusts the mpg readout...it's usually just a ballpark guess, at best.
If you really want to see some crazy numbers, put the engine in neutral and coast down a hill at 65 MPH. I think I got 160 MPG...
Here is at 55MPH:
Here is at 55MPH:
