Brake light flashing under hard acceleration
Hi all, recently i've been getting the brake light switch almost everytime i go WOT from standstill or low speed (<20mph).
I searched the archives and found mostly references to the brake switch or the speed sensors.
I'll soon be bringing the car ('01 S8) to the dealer for that transmission cable recall, should I simply ask to "check/adjust the brake switch". Or is it something a layman (i did a TB job in 3 weeks...) can do himself?
Thanks for any advice!
Martin
Martin
Re: Check brake fluid level?
If you're on the minimum mark and it goes unlevel in hard acceleration, the sensor might fire.
Not up on my S8 warning signals, but is that the same one as for the hydraulic boost system? In earlier V8s, if you are a little low there, that red warning light will go on in the same circumstance.
I understand, its rhe brake fluid level indicator, if your pads are down,the piston in the caliper
is has to take up the space of the worn brake material.That is why the light COULD come on.Either way its a sealed system, if theres a leak you'll know it.
quattromano
03-02-2011 07:15 AM
