A/C no longer works, stuck in ECON mode
The compressor(I hope it's not the compressor itself) fan works until i drive in reverse or forward and there is one clip that had been broken for sometime causing the whole frame to rattle could this have made it malfunction?
Haven't been able to check VAG-COM since I get excessive com errors through HVAC.
If it's not operating properly, the AC willnot function normally either. The electric must run 100% of the time when AC is set to "auto". If not, something is malfunctioning...the resistor pack, relay or climate control head.
"compressor fan" ?
"broken clip"? ...part of the compressor or it's mounting?
...my question: Is the electric fan (on the radiator/condenser) running at idle (engine cold and warm) while AC is blowing cold air (set to "auto")?
Have someone else change controls while you listen under the hood >>>
Is AC clutch engaging when controls are set from off to auto, while idling?
Is there plenty of refrigerant in the system?
