cd changer issues
cd changer issues
Hey guys , my changer in the trunk is reading error on all the discs. I tried to use a cleaner but it also read error. Does anyone have any suggestions. Tired of the radio please help
Label side up!
Had to check.
What error code is it giving you? There are a number of codes, each of which refer to a different issue.
I had an intermittent problem during our freezing winters, but its worked fine otherwise.
How is the weather where you are?
Similar problem here
I had intermittent problems earlier, wouldn't read some CD's, seemed pretty random which and when.
It got gradually worse from september, until november/december with error on all discs most of the time. It mostly says "No CD x" and so on. Lower temperatures has crossed my mind as a possible trigger, but there has to be an underlaying problem.
I'm fitting my new RNS-E today, so I probably won't care much about it. With 2 x 4GB SD cards and probably USB/iPod connection, who needs an ancient CD changer anyway? :-)
Re: cd changer issues
There are some answers if you do a search on cd system errors. It seems to be a bit of a problem. I am going through the same thing myself. As soon as it warms up I will attempt it.
Toy_Guy
11
11-12-2006 07:13 PM
