code P0321
Old Nov 18, 2010 | 03:48 PM
chrisaudis8's Avatar
Default code P0321
I have an audi s8 2001 and i just replaced the cam chain tensioner and when i was putting it all back together I noticed that i have a broken wire on what I found to be called the Ignition Capacitor.
It has a single brown wire going to it and it is a small black rectangle sensor that mounts to the valve cover by the #4 coil.
Here is what it says in the order it is.
It is black with white writing
Beru
Germany
0 310 025 017
4.7µF 110v-
max. 120°C
i went to the audi dealerships parts guy who can get Audi parts and he couldnt find it on his computer.
Does anyone know the real part number or what I ask for to repalce it???
Old Nov 18, 2010 | 05:15 PM
silverd2's Avatar
There's one on each side (next to #5 also)...As I understand it, the purpose of the capacitors are to suppress radio noise.
I have the same year car ('01 A8 AUX engine) . Wiring diagram only shows a circuit going from the control side ground connection of one coil pack on each side of the engine to each capacitor and then directly to engine ground...all 8 coil packs share a common ground in the engine wiring harness. So don't know how it would have any connection to P0321 code: Ignition/distributor Engine speed input Circuit range/performance...speed sensor G28 on drivers side of transmission, close to engine flange. ...But really don't know, for sure.
You're right, though...the part # doesn't exist on the web or any parts list/supplier. The part is only mentioned in wiring diagrams and a few mentions on past forums on other models of Audi/VW . All those references agree that it's just a radio noise suppressor and not critical to any other system.
Is there anything left of the wire to temporarily reconnect it?
Old Nov 21, 2010 | 11:46 PM
I managed to get the wire reconnected and the code went away. But its off to the dealer to get the immobilizer programmed then it should run again
dxd23
Mar 14, 2020 11:48 AM
themrgodly
Jun 19, 2018 09:07 AM
hanshy5
Feb 7, 2013 07:04 AM
TTRoadster225
Jun 3, 2009 05:13 AM
