coolant leak @ oil cooler
On my 01 S8 I have been quoted 5 hours labor plus parts to fix a growing coolant leak at the oil cooler. This will be close to $600 when completed.
Is this about right or am I getting the screws put to me here? Thanks for the feed back.
Jack
Jack
You might want to check this thread out
<ul><li><a href="https://forums.audiworld.com/a8d3/msgs/59047.phtml">https://forums.audiworld.com/a8d3/msgs/59047.phtml</a</li></ul>
Re: coolant leak @ oil cooler
Wow!! Fast replies ! Many thanks, I've always had trust in my mechanic. Now I'll sleep well knowing his estimate was right on. Thanks Y'all.
Jack
Jack
Paul, Emachineshop maybe an option here.
do you know the site? I bet a big order could get these well under 10 dollars each. The cuts I made work perfectly with the factory O-rings. You can sell them via Audipages.
I am going to make another with two grooves for Viton O-rings. 4 O-rings per unit! My viton O-rings are ever so slightly smaller thickness than the factory O-rings. But as cut the grooves are perfect for the factory O rings.
acidrane-teh jeweler
07-24-2006 09:11 PM
