Drivers Window
Drivers Window
I have noticed that my drivers side window "jumps" halfway down, meaning it doesnt slide down smoothly all the way. Half way it makes a noise and you can feel the sudden shake and then it continues to the bottom normally. Anyone else have this problem? I wonder if the window tint that was on the car caused this problem. I am thinking of bringing this up with the dealer to cover it as a defect. Should I?
Take a look at this thread. I'm not sure if this is "your" problem, but it's worth a try.
<ul><li><a href="https://forums.audiworld.com/a8/msgs/39042.phtml">Good luck</a></li></ul>
Re: Take a look at this thread. I'm not sure if this is "your" problem, but it's worth a try.
I found this out in the morning when I was removing the window tint on the front windows and then was lubing the channels. I ended up trimming off some of the rubber from the molding to allow the round metal piece on the glass to pass without dragging the rubber with it that then causes the clicking sound. I just hope I dont cause wind noise at highway speeds.
36valves
Canadian Discussion
18
08-04-2005 11:47 AM
36valves
20
08-04-2005 05:51 AM
idealrides
07-01-2001 09:17 PM
