Factory speaker problem.
Old Jun 1, 2005 | 08:02 PM
tonypai's Avatar
Junior Member
Default Factory speaker problem.
Anyone ever have a problem with the factory speaker? I'm trying to hook up my parrot kit and the speaker isn't responded. The fuse is ok.
Thanks.
Old Jun 2, 2005 | 05:44 AM
PaulW's Avatar
Default What speaker? The B Pillar speaker?
What output are you using? Or are you just using TAGA8's kit?
Old Jun 2, 2005 | 05:58 AM
tonypai's Avatar
Junior Member
Default Yes, the B pillar speaker
I'm using Taga's kit. We got everything to work except for the B pillar speaker. Any thoughts on why it wouldn't work?
Old Jun 2, 2005 | 06:14 AM
PaulW's Avatar
Default It should work
I would put a multimeter on the DC scale and see if you have any input to the speaker.
How are you getting to it? Through the DB-25 connector in the trunk?
If so, then take the two pins that feed the B pillar speaker and measure the resistance across them. Should be about 4 ohms. If so, then you know the speaker is good. The V60 procedure on audipages.com has the pin out.
Old Jun 2, 2005 | 06:46 AM
tonypai's Avatar
Junior Member
Thanks Paul, we'll give it a shot on Sunday.
Old Jun 2, 2005 | 07:33 AM
A8CT's Avatar
Default another way to test the speaker is to connect a 9v battery somewhere along the wiring path..
if you can do that where you tied into with the kit, you'll be testing the wiring and spkr at the same time. You shoot hear a pop if everything is ok.
Bob
Monster, now w/ Rice
Dec 5, 2004 12:43 PM
Mortt
Mar 9, 2003 04:01 PM
mbrobe
Sep 20, 2002 12:44 PM
Ed Esposo
Sep 7, 2001 06:25 PM
AvramD
Dec 20, 1999 07:09 AM
