Fault code.
Old Jun 1, 2008 | 05:35 PM
TOMAS7's Avatar
Junior Member
Default Fault code.
16826- EVAP
Emission Control Sys- Small Leak
P0442 35-10 Intermittent
I guess I have a cracked hose somewhere?
Is this canister under my spare tire? The Bentley doesn't give me an answer for the ABZ motor.
I have another unrelated question, my engine is coded 01273 (99 A8), isn't there another code that wakes the engine up?
There are various codes for the transmission, 00012, 00011, etc.
I'm sure there has to be various codes for the motor. Hasn't anyone deciphered these yet?
Old Jun 2, 2008 | 04:01 AM
ricoblanco's Avatar
Default Check this:
First take a look at the hoses leading into and exiting the EVAP Purge Regulator:
<img src="http://i255.photobucket.com/albums/hh156/ricoblanco/EVAPpurge-1.jpg">
Then take a look at the hose connecting to the intake manifold (you may wnat to use leak detection spray for this):
<img src="http://i255.photobucket.com/albums/hh156/ricoblanco/EVAPline1.jpg">
If that doesn't do it, then check the EVAP canister hose connections (under the spare tire). Finally, check the Leak Detection Pump connections by removing the drivers side rear wheel well cover to access it.
Old Jun 2, 2008 | 01:06 PM
TOMAS7's Avatar
Junior Member
Thanks a ton ricoblanco.
Old Jun 2, 2008 | 03:42 PM
ricoblanco's Avatar
No problem my friend!
Sprinkz
Dec 28, 2012 01:54 PM
mikebessxxx
Jun 17, 2008 07:39 AM
PassatInTheWrks
30v V6 Discussion
Jan 8, 2007 11:09 PM
Shap
Oct 14, 2005 09:17 AM
GeorgieGirl
Sep 29, 2004 03:41 PM
