fuel injector O-ring seals fyi
there are two O-rings on the fuel injectors, an upper, and a lower. The lower O-ring is larger than the upper, and seals between the injector and the intake manifold. The online parts places just list them both as "fuel injector seal" so I ordered the upper ones by mistake.
When I called around looking for the lower seals, one Audi dealer said "I don't have that part in my system -- I've never ordered any before" The other dealer said "we just reuse the old ones, they're usually fine."
would the O-ring kits from Harbor Freight Tools help? Hundreds, in diff sizes, $3-$12
Just put the word "o-ring" in their search area ("Find by Keyword"). A number of kits will come up.
Lots of different sizes.
If you have a Harbor Freight Tools store near you, they usually have the kits on sale for $3-$6.
Would any of those kits help?<ul><li><a href="http://www.harborfreight.com">http://www.harborfreight.com</a</li></ul>
Maybe - I'm always worried about the material specification
with any rubber (ish) parts. Those o-rings are in a pretty harsh environment, and I don't know
(a) the OEM spec
(b) the spec on any replacement parts.
Frustrating.
(a) the OEM spec
Frustrating.
Re: fuel injector O-ring seals fyi
You can usually get a kit with the O rings and pintle caps for $2.50-$3.50 each from your local auto parts store. Check around, prices vary quite a bit from supplier to supplier so there might be a $3 difference per kit (x8 kits) often from the same store. I got the kits from Autozone or Checker for my 928 and 944S2.
-Joel.
-Joel.
AudiSpaulding
11-13-2008 07:08 AM
bc9080
01-13-2005 04:21 AM
DINA
11-19-2003 01:00 AM
