Headlight (High Beam) fuse problem?
when i did my stat inspection, i found out that my right high beam is not working. strange thing is that it still didn't work after replacing the bulb. could it be the fuse? can anyone help on locating that please?
much thanks!
much thanks!
if it is only one side it is a bulb, or electrical issue. Not fuse for each side
there is a fuse for both together not each. Check the plug I had a similar issue with one of my fogs, but it turned out to be a loose plug. I knocked it just loose enough when I was working in the engine bay once. good luck
wow, I will have to look at my manual, I have do not have HID lights
every car I ever had only had one for high and one for low. not per side. Now you have me curious I will have to go look. thanks
turbosquatt
03-05-2009 05:17 AM
Fulliautomatix
04-03-2008 08:35 AM
DxC
08-09-2004 06:20 PM
ThirdEye
10-21-2002 06:21 AM
