Headlight washers not functioning, Now!
Old Jul 9, 2006 | 06:38 AM
AudiQmann's Avatar
New Member
Default Headlight washers not functioning, Now!
I filled the washer fluid res and now my washers do not function.
Old Jul 9, 2006 | 07:27 AM
KMU's Avatar
KMU
New Member
Headlights must be on.
Old Jul 9, 2006 | 11:48 AM
AudiQmann's Avatar
New Member
Yes I know. They were.
Old Jul 9, 2006 | 11:52 AM
marcodant's Avatar
Junior Member
Default it could be the pump .. I just replaced mine. I think pump was approx
$20 on ebay. to replace it all you need to do is remove the lower trim piece below the headlight and the pump is right there. pull the connector off then pull the pump straight up. the reverse the process for the new one. I figured this out after I pull the air box out and removed the whole washer reservior.. I found that I could of just removed that trim piece below the headlight and saved lots of time. good luck
Old Jul 10, 2006 | 06:28 PM
AudiQmann's Avatar
New Member
Default Today as I was washing the windows to give one last try to see if the sprays were working and
BAMM!! Spray..
Must of had air pocket when I ran out of fluid.
Old Jul 16, 2006 | 10:06 AM
AudiQmann's Avatar
New Member
All shot Now!!! Not working anymore and res is full. er As full as it can be.
97RoninA8
Nov 27, 2006 05:51 PM
kepstein
Audi 100 / A6 (C4 Platform)
Nov 24, 2005 06:04 AM
Audi1.8T
Aug 10, 2005 12:56 PM
Silver85TC
Feb 28, 2005 11:50 AM
SiV6Qcoupe
9
Jul 27, 2001 06:29 PM
