Help - How to replace windshield washer pump
Old Nov 12, 2002 | 03:21 PM
sluke's Avatar
New Member
Default Help - How to replace windshield washer pump
Would anyone have experience replacing a windshield washer pump. I removed the air filter housing and could not figure out how to remove the washer fluid resevoir. I was told this is necessary to access the pump. Any help would be greatly appreciated.
Old Nov 12, 2002 | 04:33 PM
gdaniel's Avatar
Default Re: Help - How to replace windshield washer pump
My 97 came with a bad windshield washer pump. I waited for the Bentley CD and went to work with my mechanic. There is a problem with the Bentley procedure. Paraphrased from the "book":
Remove air cleaner cover and air cleaner.
Remove the bolt along the upper edge of the reservoir. Disconnect the hoses and connectors from the pumps. One is the headlight washer pump and one is the windshield. Remove the reservoir from the engine compartment. The problem is that this procedure didn't work on my 97. There is a bracket welded to the fender just above the filler neck that prevents lifting the reservoir to get to the pump. We ended up removing the fender well behind the front wheel. This allowed the reservoir to be turned so that the neck could pass under the bracket. It wasn't easy to reach everything to get it back together again. This is one of Audi's great maintenance designs.
Old Nov 17, 2002 | 04:04 PM
sluke's Avatar
New Member
Thanks for sharing your experience! I'll tackle this project before the snow falls!
Old Nov 17, 2002 | 04:05 PM
sluke's Avatar
New Member
Old Dec 12, 2003 | 05:39 PM
radglad's Avatar
New Member
No real clear answers here!
What is the recommended method?
Old Dec 12, 2003 | 06:03 PM
radglad's Avatar
New Member
any help greatly appreciated!!
HotGo
A4 (B7 Platform) Discussion
May 28, 2017 02:48 PM
betagear
Q5/SQ5 MKI (8R) Discussion
Apr 1, 2015 01:06 PM
kaodixflow
Jun 24, 2009 01:44 AM
kk's woW12
Mar 11, 2006 03:29 PM
wmbear2019
Audi 100 / A6 (C4 Platform)
Jul 24, 2003 09:32 AM
