help with recent problem
Old Jul 21, 2004 | 02:37 PM
GlenC's Avatar
New Member
Default help with recent problem
So, I let my wife have the car today for a long trip to Harrisburg, and sure enough half-way home she gets an MIL light and the car goes into limp mode. Pulled the faults and here's what I got:
18169 shift lock solenoid (N110) short to ground
P1761-35-00...
18032 MIL request signal active
P1624-35-00--- intermittent
Any help on this greatly appreciated. Thanks.
Glen
Old Jul 21, 2004 | 05:37 PM
PaulW's Avatar
Default What the Bently Says
For 18169, shift lock solenoid (N110) short to ground
---------Bently says-----
Possibilities:
Missing supply voltage for solenoid -N110-
Solution:
- Check wiring and connections per wiring diagram.
Second Possibility:
Short circuit to GND 1)
Solution:
Read measuring value block, display group 003 page 01-80 .
Carry out electrical testing page 01-110 .
Display Group 003, field 2 is the Shift lock solenoid -N110- activation
You need to look at that and figure out what it does.....if it's a short circuit to ground.....then it blew a fuse....
Find the problem and correct it.
Car goes into limp mode??? Does that mean that the tranny goes into limp mode??? That's when all the lights light up on the dash (PRND432) and it opens the torque converter and drives in 4th gear.
If that's the case, she's good to drive the car, even though it won't be smooth.....she can drive it home.
In regard to 18032....it means the check engine light is on....this is what it says to do:
- Check DTC memory via "Automatic Test Sequence" by inserting address word "00"
Only certain faults on the tranny trip the CEL....it does this through the CAN bus on the car....even though it's a 97-99 (pre facelift) it had a CAN bus or multiple CAN buses.....
pw
Old Jul 22, 2004 | 03:34 AM
GlenC's Avatar
New Member
Default Thanks Paul
I haven't been around much lately, and just when I started to fall in love with the car again, this happens. I'll let you know what transpires. Cheers
lurch417
Audi 100 / A6 (C4 Platform)
May 29, 2008 02:11 PM
quattro_silver
Aug 22, 2003 08:00 PM
Agent Orange
14
Oct 21, 2002 09:11 AM
imaudi5
Misc. Models Discussion
Oct 26, 2000 08:05 AM
pjv
Aug 31, 1999 11:22 AM
