I got the Engine Speed Sensor fault code again. Cleared it. Why does it keep comming back? Normal?
Old Feb 7, 2005 | 05:52 AM
Mitaka's Avatar
Old Feb 7, 2005 | 05:58 AM
PaulW's Avatar
What code?
Old Feb 7, 2005 | 07:29 AM
Mitaka's Avatar
Default Here is my original post a few months back
<ul><li><a href="https://forums.audiworld.com/a8/msgs/82548.phtml">https://forums.audiworld.com/a8/msgs/82548.phtml</a</li></ul>
Old Feb 7, 2005 | 07:56 AM
PaulW's Avatar
Don't think it's really a big deal.....does the car run okay?
Old Feb 7, 2005 | 08:22 AM
user 62970120212's Avatar
Banned
Default The sensor could be failing, it could affect ignition
At least on the 5V engine, that sensor provides the high resolution crankshaft position signal for ignition timing. If its signal is weak, it could be failing, and I don't know if the engine runs badly or not at all without it. So I'd replace it if its wiring and connections appear okay.
Tom
Old Feb 7, 2005 | 08:32 AM
PaulW's Avatar
Default If it goes bad, the 32 v engine gives a default signal
Can't remember how it works.....but it will default something. This would lower performance.
Old Feb 7, 2005 | 08:53 AM
Mitaka's Avatar
Default Yes engine seems to be running OK. It is just the vibration that was happening right before stop...
Where is this sensor located. Is it easy replacement?
Old Feb 7, 2005 | 09:24 AM
PaulW's Avatar
On back side of left hand head....check the audipages TB replacement procedure for details
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 7, 2005 | 10:13 AM
Mitaka's Avatar
Thanks will do
mthomas777
Dec 17, 2012 05:23 AM
agrandy
Jun 9, 2008 05:26 AM
adminisTerTurbo
Audi Original "S" Cars
May 17, 2008 10:40 AM
zoofs4
Jan 6, 2006 04:02 AM
quattromano
Jul 22, 2003 09:45 AM
