Engine Speed Sensor - Error code not clearing after replacement
16706 - Engine Speed Sensor (G28) No signal
P0322 - 004 - No Signal/Communications – Intermittent
So as advised in previous posts, I replaced the Engine Speed Senor, however, the error message initially disappeared and then came back later. Thinking it was a fault with the replacement speed sensor I replaced it again however, the error code is not disappearing.
Due to the error code sometimes the car doesn’t start up first time around and I need to keep the ignition key turned on to get it started and then the EPC light comes on. If I turn off the engine and restart it all is fine.
Can some please advise what could be wrong? Any suggestions on what I could do to resolve the problems. Is the car safe to drive like this? All suggestions would be really appreciated.
