Large EVAP Leak
Large EVAP Leak
I have been working on a large EVAP leak CEL problem for a few months now. I think I had more than one leak. Anyway, now I only get the error code when the tank is low on gas. I have heard this is probably the sending unit gasket, I was wondering if anyone can confirm this.
The Bentley procedure for leak testing does not work too well.
Thanks
Thanks
Re: Large EVAP Leak
I had similar problem on my 99 A8. I would definately replace the sending unit gasket and then test the leak detection pump (LDP) using ross-tech Hexcom ( Grp 32 or 33 I will look it up). If it detects a leak, clamp the hose to evap purge valve and rerun the LDP test. If the pressure holds and output of test is "evap OK"
then purge valve(n-90 frequency valve) is leaking and will need replacing ($100). You may try cleaning it with carb cleaner since problem is build up of soot inside it. I can email detailed instructions if you require them
kpatz
15
11-26-2017 05:13 PM
Zzak
11-29-2004 06:02 PM
