my temperature logo lighted up while on an exit ramp...
you know the one that indicates a thermometer and lines,well it flashed when I was havin fun with the car in a tight turn any ideas,? is it not enough antifreez?
Re: Yes, it's the float switch in the resevoir
<center><img src="http://pictureposter.audiworld.com/103666/audi_a8_009_low.jpg"></center><p>could this be one of them?that orangee color?
The coolant OR the switch
Besides the possibility of a coolant leak (bad hose somewhere or bad thermostat causing overheating and resulting water loss are the most likely, or the low probability dreaded blown head gasket or worse), make sure the bottle sensor itself is okay and is plugged in. If you worked around the water bottle area, it could be dislodged. If bottleis visually low, obviously that's not it and its a leak issue.
Start here
<ul><li><a href="http://www.audipages.com/Tech_Articles/enginemechanical/coolantexpansiontankreplacement.htm">And wash that engine! What are you waiting for?</a></li></ul>
raj//UrS4
Audi Original "S" Cars
02-26-2007 05:27 PM
