Overheating problem - possible solution
Secondly, we still dont know why you are over heating. How much cooler does it run while you are driving 40? If it dosent help then there is no fan or air movement that will help you.
My mechanic says that it might be due to the elec. fan not spining at the max speed adn should be replaced. i dont know if it will mak ethat much of a difference
what do you think?
right now the fan sometimes does not engage by itself and needs to be wound once to get it going...
Everything ive read about this sort of problem points to the Fan...fan clutch...and now that it has been replaced... confused
It has three speeds. If the HVAC is in AUTO, then the low speed is always on, it turns the fan off when in ECON and less than about 95C.
When you get above about 95C in AUTO, it switches to the 2nd speed, then if the needle goes up to 120C, it would be in the third speed.
I would be looking at the fan, and considering replacement if it has not been replaced previously.
Good luck!!!
