From R to D then suddenly limp mode...
Hello all knowing Audi fanatics
I am having trouble with my automatic transmission. Google has not helped.
When I park the car and I have to reverse from a parking space and then put it in to Drive it sounds funny and goes into Limp mode.
I always reverse to the parking spot when parking due to this problem.
I had the filter and transmission fluid changed but it did not solve the problem.
What I think is going on and that is what I hope is my problem is that there is a sensor that is not working correctly.
Could you guys please help me solve this problem and/or come with some ideas ?!
Best regards.
Best regards.
Hello 4Driver4
The Code I got was P0703
After some googling
https://www.obd-codes.com/p0703
Symptoms of a P0703 code may include:
Engine stalling when the vehicle rolls to a stop
TCC lockup may be disabled
Diminished fuel efficiency
Decreased engine performance (especially at highway speeds)
Erratic transmission shift patterns No stop lamp illumination
Potential causes for this code to set are:
Defective brake switch
Misadjusted brake switch
Shorted or open wiring and/or connectors in the brake switch circuit designated as B
Blown fuse or burnt fusible link
Faulty PCM or PCM programming error
Read more at: https://www.obd-codes.com/p0703
Copyright OBD-Codes.com
The Brake ligths come and I dont have those symtoms :/
Any Ideas ?
After some googling
Any Ideas ?
You can adjust the switch you have, they often wear down a bit so they need to be adjusted again so both circuits operate as expected. The other circuit can be checked in VCDS.
