Rear Window Shade
Thanks again!
You'll want to start by removing the rear shelf covering (right behind rear headrests). It is held in place by metal pins, and requires a lot of force to remove. Be careful, but assertive ;-)
Once you've got the cover off you should be able to see the actual mechanism below. This should give you a visual indication of what might be wrong. There could be a seized arm that needs lubrication. I've also heard of broken/bent pieces, which may require replacement.
At any rate, get an extra set of hands on deck to press the buttom while you watch.
Let us know your observations.
