Throttle Cable - Transmission Behavior
EDIT: Idle smoothed out somewhat, too.
2. How tight should it be? should it be about to move up and down about 1 inch or so or should it be pretty taugh...ie guitar string...no sagging?
Lemme know.
I don't have a Bently or other technical resource, so my procedure could be incomplete or incorrect. I remember reading somewhere that an idle switch adjustment has to happen whenever a throttle cable is adjusted?
Anyway, the pedal is tight and the car drives a lot better. It didn't fix all of the little annoyances, but it did make a big difference in my situation. I still get the occasional bump going down hill, etc..., but it accelerates a lot better.
Also, it's simple to check.
Hope that helps.
